It is currently 26. Apr 2024. 02:50
Reply to topic  [ 7 posts ]
Kupujem više dijelova
Post Kupujem više dijelova
Tko mi može sve dijelove sastavit na kup i ponudu napravit, bio bih veoma zahvalan!!! :klanjanje:
mali edit, neke djelove već imam
2 Black 32006 Technic Beam 4 x 0.5 Liftarm with Boss
2 Black 3713 Technic Bush
1 Black 64781 Technic Gear Rack 1 x 13 with Pegholes and Axleholes
2 Black 32013 Technic Angle Connector #1
2 Black 45590 Technic Axle Joiner Double Flexible
8 Black 32449 Technic Beam 4 x 0.5 Liftarm
4 Black 32348 Technic Beam 4 x 4 Liftarm Bent 53.13
5 Black 32316 Technic Beam 5
1 Black 32525 Technic Beam 11
2 Black 32278 Technic Beam 15
2 Black 32039 Technic Connector with Axlehole
2 Black 32184 Technic Cross Block 1 x 3 (Axle/Pin/Axle)
1 Black 32269 Technic Gear 20 Tooth Double Bevel
2 Black 64782 Technic Panel 5 x 11
8 Black 44309 Tyre 43.2 x 22 ZR
2 Blue 32034 Technic Angle Connector #2 (180 degree)
4 Blue 6536 Technic Cross Block 1 x 2 (Axle/Pin)
2 Blue 32316 Technic Beam 5
2 Blue 32524 Technic Beam 7
2 Blue 41239 Technic Beam 13
10 Blue 4274 Technic Pin 1/2
2 Dark Bluish Gray 41677 Technic Beam 2 x 0.5 Liftarm
6 Dark Bluish Gray 6632 Technic Beam 3 x 0.5 Liftarm
2 Dark Bluish Gray 32056 Technic Beam 3 x 3 x 0.5 Liftarm Bent 90
2 Dark Bluish Gray 32449 Technic Beam 4 x 0.5 Liftarm
2 Dark Bluish Gray 2905 Technic Beam 5 x 3 x 0.5 Liftarm Triangle
5 Dark Bluish Gray 32525 Technic Beam 11
2 Dark Bluish Gray 32278 Technic Beam 15
4 Dark Bluish Gray 32526 Technic Beam 3 x 5 Bent 90
1 Dark Bluish Gray 32034 Technic Angle Connector #2 (180 degree)
2 Dark Bluish Gray 6587 Technic Axle 3 with Stud
2 Dark Bluish Gray 60484 Technic Beam 3 x 3 T-shaped
2 Dark Bluish Gray 32009 Technic Beam 3 x 3.8 x 7 Liftarm Bent 45 Double
6 Dark Bluish Gray 32316 Technic Beam 5
3 Dark Bluish Gray 32524 Technic Beam 7
1 Dark Bluish Gray 48452cx1 Technic Turntable New with Hole Base (complete assembly)
1 Dark Bluish Gray 42003 Technic Cross Block 1 x 3 (Axle/Pin/Pin)
4 Dark Bluish Gray 41239 Technic Beam 13
5 Light Bluish Gray 32054 Technic Pin Long with Stop Bush
1 Light Bluish Gray 4150 Tile 2 x 2 Round
2 Light Bluish Gray 42610 Wheel 11 x 8 with Center Groove
4 Light Bluish Gray 56145 Wheel 43.2 x 22 without Pinholes, with External Ribs
5 Light Bluish Gray 6536 Technic Cross Block 1 x 2 (Axle/Pin)
1 Light Bluish Gray 42003 Technic Cross Block 1 x 3 (Axle/Pin/Pin)
6 Light Bluish Gray 48989 Technic Cross Block 1 x 3 (Pin/Pin/Pin) with 4 Pins
1 Light Bluish Gray 32291 Technic Cross Block 2 x 2 (Axle/Twin Pin)
2 Light Bluish Gray 41239 Technic Beam 13
2 Light Bluish Gray 40490 Technic Beam 9
4 Light Bluish Gray 32006 Technic Beam 4 x 0.5 Liftarm with Boss
6 Light Bluish Gray 6632 Technic Beam 3 x 0.5 Liftarm
1 Light Bluish Gray 6143 Brick 2 x 2 Round Type 2
4 Light Bluish Gray 32525 Technic Beam 11
4 Light Bluish Gray 62531 Technic Panel Shell 11 x 2 x 3
6 Light Bluish Gray 41677 Technic Beam 2 x 0.5 Liftarm
2 Light Bluish Gray 32056 Technic Beam 3 x 3 x 0.5 Liftarm Bent 90
2 Light Bluish Gray 32449 Technic Beam 4 x 0.5 Liftarm
2 Light Bluish Gray 2905 Technic Beam 5 x 3 x 0.5 Liftarm Triangle
2 Clear 4073 Plate 1 x 1 Round
1 Trans_Orange 58176 Cylinder Domed 1 x 1 x 1.667 with Bar
2 Trans_Flu_Orange4073 Plate 1 x 1 Round
2 Trans_Red 4073 Plate 1 x 1 Round
1 Red 32039 Technic Connector with Axlehole
1 Red 2431 Tile 1 x 4 with Groove
1 Red 4162 Tile 1 x 8
3 Tan 3749 Technic Axle Pin
1 White 2431 Tile 1 x 4 with Groove
08. Dec 2014. 15:04
Post Re: Kupujem više dijelova
Čisto sumnjam da će ti netko ići kroz cijeli popis jer nema slika. Jesi li probao napraviti wanted listu na bricklinku pa potražiti dučane koji nude sve te dijelove? Istina je da ćeš teško naći sve u jednom dučanu, ali također je teško da ćeš nači ovdje nekoga tko ima sve te silne dijelove, tj. ako ih netko i ima, velika je vjerojatnost da ih ne prodaje jer i sam/sama slaže uglavnom technic...
Instagram
Flickr, owned Brickset, wanted
08. Dec 2014. 15:20
znam za bricklink online trgovinu, ali nisam shvatil kak se puni wanted lista
08. Dec 2014. 15:46
slike i linkovi bi bili super
08. Dec 2014. 16:09
Bricklink je više kao ebay bez bidanja nego samo trgovina. Nakon registracije odeš na catalog i nađeš dio koji ti treba ( npr ) Drugi stupac ti je "On Wanted Lists:(Add to My Wanted List)"
Klikni na linkić "Add to My Wanted List". Na sljedećem ekranu možeš kliknuti na view image (korisno ako prtljaš sa više otvorenih tabova), ispod toga biraš boju i na koju od svojih wanted lista želiš da dio bude dodan (osobno imam 10ak listi, a dijelove je kasnije lagano prebacivat sa liste na listu). Ispod toga biraš dal' tražiš nove, used ili nebitno. Ispod toga možeš ukucati minimalan broj komada dotičnog lota.
Kada ti je lista gotova, ideš na "wanted" tab. On ti izbaci ispod podtabove, a tebi je trenutno najbitnije "my wanted list" za editiranje i "by shop" za listanje kroz dučane koji imaju dijelove sa liste.
Tab "by shop": Gore desno imaš opcije da tražiš sa svih svojih lista ili samo jednu ( Show Single Selections ). "sort by" odaberi "Lots (unique)".
Nađeš li neki zanimljiv dučan, u samome dučanu možeš opet vidjeti što se nudi sa tvoje liste kroz 2 opcije:
"Show All Items this store has on my Wanted List" (uzima u obzir broj komada koji si naveo kod dodavanja elementa )
"(All Items)" - zaobilazi broj komada, samo traži lotove.
Prije kupnje obavezno provjeri feedback (link je brojčica na vrhu dučana npr. "Maintained by ToyBrickBrigade (39344) 99.08% Positive Feedback from 59025 orders"). Ako je feedback ok, obavezno pročitaj "splash" i "store terms" da vidiš dal' ima skrivenih troškova (neki naplaćuju sortiranje, provjeri minimal buy).
Ove upute pišem navrat-nanos, nadam se da se nisi pogubil :LEGO39:
Instagram
08. Dec 2014. 16:34
ma znam..imam već kupovine na toj stranici, samo nikad nisam obračal pažnju na wanted opciju :)
budem proučil malo
09. Dec 2014. 00:12
uhhh, stvarno si detaljno opisal to :))
svaka čast!! hvala :)
09. Dec 2014. 00:21
Users browsing this forum: No registered users and 6 guests
